7 members (Hotrod Lincoln, mason86, klhansen, 32Fordpuchoptop, Ponchogl, Phak1, tclederman),
76
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,672 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 209 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 209 | I suck at body work...i dont know wat the heck im doing! I have this big dent in the rear side of the bed. banged some of it out. Used that tool were you drill a hole in the bedside then pull it out with i have no idea wat its called. my god i put bondo. Its sad cause after i put the bondo to cover the holes,i then sanded it down and put some flat black. Its horrible lookin cause you can see where the bondo is. I am a true amateur. Or is it nub.  ...and the truck bedside is still dinged up. GGGGrrrrr!!!
Stovebolt-It is painted
| | | | | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | The tool you used is called a slide hammer. The usual procedure to fix a dent is: - straighten metal as close as possible - sand the surface w/ 80 grit to bare unrusted metal - Apply bondo so that extends well beyond repair - Sand the bondo flat with a long board sander - If surface is still not flat knock down high spots and fill low spots w/ more bondo and sand again - Prime repair area - Sand primer and painted surface w/ 220 or finer paper - Top coat with paint
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
| | | | | Joined: Oct 2004 Posts: 209 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 209 | Thank you cujo. I will try these steps out. Ill let you know how it comes out.
| | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | We all stink at first. The good news is that you can just keep after it until you get it right. Sometimes, you just have to walk away for a few days and tackle it again.
One thing to remember is that the texture of body filler is different from metal. If you don't want to see the body filler, you'll have to sand it with 600+ grit. Even if everything is perfectly smooth, you still may see the body filler due to textural differences unless you are patient enough to sand (and sand and sand and sand) with the fine grits.
Good luck! | | | | | Joined: Oct 2004 Posts: 209 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 209 | Thank you kim. I will do my best
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | Hey BIGBAMBINO remember that when you apply bondo, do so in layers, if you were not able to pull the metal as flat as possible like cujo8 says. that way the layers are throughly dry and set up and you don't have one big chunk of bondo in one spot. i know it not the bolters way but you could have some shop do the rough work and you learn to do the extensive finish work. as kim says we all sucked the first couple times but you can do it.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
