4 members (Bill Hanlon, Hotrod Lincoln, Brian Moore, Hush), 50 guests, and 3 robots.
Topics128,090
Posts1,056,026
Members48,432
#1170387 06/20/2016 4:17 AM
Is it possible to hang the cab from the rafters? I don't plan on lifting it that way, just temporarily until I get things moved around.
I'll be lifting it with my cherry picker.
My shed is 30 foot wide. I have 2 2x10 rafters sandwiching a 2x6. The shed was originally trussed, but the PO added the 2x10's and cut out the truss stringers for extra ceiling height. The rafter joints have plywood holding them together, rather than the beat on plates.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Sounds like you're asking if the roof rafters will hold the weight of the cab. That's really a question for a structural engineer but I'll give you what I think (just a mechanical engineer). If the roof was originally designed with trusses, the bottom chord of the trusses was in tension and kept the weight of the roof from letting the rafters push the walls out. Unless the 2x10 modification replaced the ability of the bottom of the trusses to keep the rafters from hinging at the peak, I'd be real careful about it. If the 2x10 sandwiching the rafters make up a triangle at the peak with a significant horizontal base dimension, then maybe the modification was correctly engineered. Although if you've had snow build up on it and it survived that, the weight of the cab would probably be equivalent and you wouldn't bring the roof down, at least till winter with the snow load if you left it hanging that long.
Whitedog #1170420 06/20/2016 12:53 PM
What if you place a temporary support column on either side of the rafters supporting your cab? A 2x4 or 4x4 from the floor to the underside of the rafter.
Dave from Northern Kentucky
My 54 3100
