1 members (Ponchogl),
133
Mod | | | Forums66 Topics128,265 Posts1,058,365 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2002 Posts: 154 'Bolter | | 'Bolter Joined: Aug 2002 Posts: 154 | Ok I have a 1954 235 truck block bored .040,a 1957 848 head a 1957 new 261 solid cam and a 1951 216 flywheel and bell housing. If I try to time it on the BB it runs like crap and spits back through the carb. I was resetting the timing and I started advancing it and it started running better. When I checked it with the timimg light, the marker was on the triangle not the BB.It quit spitting back through the carb and ran a lot better. My question is could the BB on the 51 216 flywheel not be the right mark to time on for the 54 235?? Am I going to have to use the "PING" test to to time this thing??? THANKS Eric | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Eric, I have a similar amalgamation of parts, and ran into a similar situation recently. https://www.stovebolt.com/ubbthread...5_tune-up_advice_needed.html#Post1167873When timing to max vacuum, it was about 10 degrees advanced according to a timing light. I am in the process of field testing with the "ping" test. Paul | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The markings on different years/engines flywheels differed over the years.
The vacuum timing and "ping" techniques are more reliable than using timing marks. The BB and/or other marks are usually good for getting you close enough to start and warm up the engine. | | |
