5 members (37 GC, ShopRag, klhansen, Hotrod Lincoln, 1 invisible), 189 guests, and 2 robots.
Topics128,147
Posts1,056,797
Members48,454
#1169310 06/14/2016 12:53 AM
Just found what looks to be a 57 Cameo, I need help deciphering the vin, to see if it's a true cameo. I can't make head or tails.I think I have up to the K figured out, Just need Production Sequence figured out. your would be appreciated. Thanks in advance
Vin# V3A57K138896
1952 Chevy Suburban
1964 Chevy Suburban
1965 Chevy Suburban 4X4
1941 Chevy Truck
1948 Sedan Delivery
2000 K2500 Suburban
2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
There isn't any special code in the serial number for the Cameo, hey use the same codes as the other Task Force trucks. The number you have breaks down as this; V- V8 engine, 3A- 3100, 57- 1957, K- Kansas City, MO assembly plant, 138896- Sequential serial number, starting at 100001, making your the 38895th truck built at that plant.
Bill Burmeister
What does the bed look like? Is it fibreglass? If so, that's a Cameo bed. To be 100% certain, try contacting the Kansas plant and see if they still have info on the truck or contact GM archives.
1959 3100 Apache Fleetside
Sir Searchalot
Sir Searchalot
There could be clues, but all circumstantial:
1. CAB AND BED SAME ORIGINAL PAINT COLOR!!!!(under the layers) and it's Cameo correct and per paint code. Bingo! (Other models shared some Cameo two tone colors.)(57 should have a paint code plate)
2. Any chalk markings indicating 3124
3. Correct bed and etc.
4. Big rear window
5. "Custom" cab features.
6. Fender spear 3124
7. History/previous owners recollection or old pix.
8. Since there is no real way to tell, there no way to dispute someone who says its "not a clone". What would it matter to the value if it was all correct parts/accessories/features/original color? Nothing. But Buyer beware.
Thanks for the tips
1952 Chevy Suburban
1964 Chevy Suburban
1941 Chevy Truck
1948 Sedan Delivery
2000 K2500 Suburban
2008 K1500 Suburban
Does it look like this?
http://s32.photobucket.com/user/coilover/media/Cameo001.jpg.html
http://s32.photobucket.com/user/coilover/media/Cameo002.jpg.html
bartamos gave all the clues needed to ID a Cameo. If there is any interior left the Cameo interior was different from regular pickups.
Evan
