| | | Forums66 Topics128,130 Posts1,056,702 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 98 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 98 | Just found what looks to be a 57 Cameo, I need help deciphering the vin, to see if it's a true cameo. I can't make head or tails.I think I have up to the K figured out, Just need Production Sequence figured out. your would be appreciated. Thanks in advance Vin# V3A57K138896
1952 Chevy Suburban 1964 Chevy Suburban 1965 Chevy Suburban 4X4 1941 Chevy Truck 1948 Sedan Delivery 2000 K2500 Suburban 2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | There isn't any special code in the serial number for the Cameo, hey use the same codes as the other Task Force trucks. The number you have breaks down as this; V- V8 engine, 3A- 3100, 57- 1957, K- Kansas City, MO assembly plant, 138896- Sequential serial number, starting at 100001, making your the 38895th truck built at that plant.
Bill Burmeister | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | What does the bed look like? Is it fibreglass? If so, that's a Cameo bed. To be 100% certain, try contacting the Kansas plant and see if they still have info on the truck or contact GM archives.
1959 3100 Apache Fleetside
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | There could be clues, but all circumstantial: 1. CAB AND BED SAME ORIGINAL PAINT COLOR!!!!(under the layers) and it's Cameo correct and per paint code. Bingo! (Other models shared some Cameo two tone colors.)(57 should have a paint code plate) 2. Any chalk markings indicating 3124 3. Correct bed and etc. 4. Big rear window 5. "Custom" cab features. 6. Fender spear 3124 7. History/previous owners recollection or old pix. 8. Since there is no real way to tell, there no way to dispute someone who says its "not a clone". What would it matter to the value if it was all correct parts/accessories/features/original color? Nothing. But Buyer beware.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2006 Posts: 98 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 98 |
