0 members (), 191 guests, and 2 robots.
Topics128,089
Posts1,056,141
Members48,436
#1170053 06/18/2016 4:30 AM
I have a decent low mileage '52 horn getting juice but no toot.
Any tips on fixing this???
I greatly appreciate any ideas.
Ron Albany NY
Does it make any kind of noise or vibrate at all? Has it worked before? Is it getting a good ground? If not, then the horn probably died......
1959 3100 Apache Fleetside
It's been a while since I worked on mine to get it working, but as I recall I took the back cover off and fiddled with the adjustment screw until I got it working.
Clean one of the posts on the horn and run a clean/big ground wire to a ground strap bolt - to test the quality of your ground.
May need to clean the oxidation off of the contact points.
Lots more pictures
Test of editing a post.
When I got my '48, the horns didn't work. I slipped a razor blade between the vibrating pieces of Bakelite (I think that was the material), and they worked. I think they were stuck.
Ron,
This may help you.
Horn Repair
Harold
Harold
