1 members (baldeagle),
30
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2016 Posts: 43 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 43 | Any one have any idea ? I recently rebuilt my 216 on my 40 chevy half ton pick up .. So i took i for a test drive and im getting a screching noise from what sound like the clucth rubbing .. I tried ajusting the clucth and no luck the noise still there heres the scenerio .. Im idleing no noise as i put into first no noise shifts into first good accelerate cant tell if noise is there but as soon as i let off gas pedal it sounds like something rubbing or scrapping i pop in the clucth and the noise goes away .. Same in all gears including reverse .. I havent rebuilt trans but seems like trans is good since goes into gear ok . In another chat some mentioned the pilot bushing causing noise and recomended a pilot bearing has any one experienced this issue .. And i have a new throw out bearing dont think thats it .. I did use a pilot bushing and seems everyone i ask also used a pilot bushing | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | what was it doing prior to rebuilding the engine Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Is the clutch plate installed backwards? I did this once... But it rubbed and screeched constantly unless the pedal was depressed. Terrible racket and it wrecked the clutch. | | | | | Joined: Mar 2016 Posts: 43 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 43 | no i made sure clucth is in correct way | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Find someone with a lift you can put it up on. Get a helper. Raise the truck up and start it. Have your helper engage the clutch and shift to various gears while you are underneath listening. You can use a long (18 to 24 inch or longer) screw driver or bar and hold it to different places on the bell housing and or tranny and the handle end to your ear. Acts like a Dr's stethescope. You should be able to pinpoint the area of the screeching noise. Good luck.
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Could one of the bolts be a bit too long and dragging?
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Mar 2016 Posts: 43 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 43 | Hey dennis and martin two very good ideas thanks let me look into this guess i got my weekend cut out for me thks very much | | | | | Joined: Mar 2016 Posts: 43 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 43 | Finally got my truck on a lift to see where noise was originating from and per my mechanic coming from my rear end he said my drive line to rear end needed to be ajusted. something like it was rubbing against my carrige ? Im kind of in a situation where im wondering if my previous mechanic is to blame ? because before rear end started making noise i had my seals replaced on my ball joint and front pumkin gasket my rear end wasnt making noise prior to that . The mechanic that diagnosed my noise problem is a diffrent machanic than the one that replaced my seals. I asked this mechanic if he thought the work that was previously done had any thing to do with this problem of my rear end needing ajusting and he said he doesnt think so becuase if all the previous mechanic did was seperate and install gaskets then he should have not needed to mess with adjustment. Does any one have any input or expertise in work associated with replacing the ball joint seals and pumkin gaskets to know whether or not this would of caused my rear end and driveline system to be trown out of adjustment. | | |
