6 members (3800GUY, GIJOE298, homer52, Bisbee, Steve_H, Otto Skorzeny), 139 guests, and 2 robots.
Topics128,148
Posts1,056,813
Members48,454
#116966 07/15/2005 10:17 PM
Any great ideas for polishing the stainless steel parts like: headlight rings, hood side strips...etc.?
I figured I would use some mild steelwool and some chrome polish.
What process have you all done?
Regards, Kevin
1940 1/2-ton (Uncle Willie\'s truck)
Thanks for the help so far fellow Bolters!
#116967 07/15/2005 11:48 PM
Kev - the steel wool will cause a 'haze' on SS that you'll never brighten up - need polishes meant for SS if the trim really needs brightening - if it's already pretty good, some quality polishes can put a good shine on, but do skip the steel wool!
I have hade really good results using a scotch brite pad followed up with varies grits of sand paper, up too 1200 grit. I then used a brand of polish called Heavy metal polish. First thing they list is SS . Here is thier link.
http://heavymetalpolish.com/
Stuart
Try using Tooth paste the regular white stuff. I used it to polish a grill I bought on ebay. Tooth paste dosent have all the harsh chemical that chrome polish will have in it.
Good luck
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
Thanks guys. The Stainless steel items are pretty corroded, and with paint overspray, so I thought I would need at least as rough as scotch bright. It would probably be best to start really mild first, then work my way up.
Does anyone ever chrome these items? Or would that be a Bozo No No!
Thanks for the advice!
Regards, Kevin
When stainless comes into contact with steel, such as with the use of steel wool, tiny particles of iron are embedded in the stainless. When it gets wet rust stains will appear out of what appears to be a spotless piece. Beware!
I've been using some Bronze Wool I got at Ace Hardware..Comes in different grades..coarse to extra fine..Specifically notes on the package that it won't leave particles that will rust, I originally bought it to clean my aluminum wheels, and it works very well..Steve
#116973 07/17/2005 11:44 PM
V
V Offline
Why dont you just polish them with a buffer?You can buy a decent bench mount buffer from Sears for about $100 and do them your self.I buy the polishing compound at a local rock shop for $3 a bar.
Gangster whites and straight pipes.....
go to your local auto parts store, go to the cleaner/wax/polish isle and look for a little silver can of Never Dull. Works great- it's a wadding soaked with the polish, so it's super easy too.
Apprentice
Apprentice
I use 3M prefect it II fine cut rubbing compound it works great
