| | | Forums66 Topics128,060 Posts1,055,837 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | It's raining in ontario . Just curious as my wipers are not the greatest .anyone take apart a vacuumed wipermotor and are they repairable . My wipers work very slowly and get stuck right in the middle of the window I have to reach under dash and pull on the wipers arm to help it along .I greased up the joints and it helped a bit and my fuel pump is a regular pump does not have the assist for the wipers on it . Wondering how does other trucks wipers work for fellow bolters. | | | | | Joined: Jul 2013 Posts: 159 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 159 | Mine was totally seized. I opened it up and cleaned out the old hard grease. the leather paddle wasn't too worn so I greased it all up with Vaseline and put it back together. Works great now in the bench test. I added the vacuum pump type fuel pump to get the most out of it. | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | Not original, if that is what you are going for, but I switched mine of electric. There are lots of conversion kits out there and mine works well. | | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | I guess it won't hurt to take it apart ,maybe even I will take apart my spare that is different anyway to see how it works and then try the one on my truck.if all else fails maybe even look into a electric wiper but looks like I would have to go to 12 volt. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A 6V electric motor was an option in 1954. I have one in my Suburban. | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | If you can find a "tomato can", put that on your truck and plumb it in the vacuum port. That will give you extra vacuum to assist running your wiper motor.
1959 3100 Apache Fleetside
| | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | Lots of options thanks I will keep a eye open for a 6 volt electric and will try cleaning the vacuum motor and won't cost anything to put a tomato can in the line thanks again | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | "Tomato can" is slang for the cannister that was attached on the inner fender with an "in" and "out" for vacuum lines. It was called that due to it resembling a large tomato juice can.
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I took mine apart and cleaned and that was 8 years ago and it's still working.Check out what I did on my pics under tico cleaning hope it will help.
Pete
| | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | the motor is pretty easy to take apart, clean, and relube. It should work better once doing that, although not as good as an electric motor. I had vacuum wipers on my Willys wagon. Drove it as a daily driver (in Seattle, known for rain!) and wheeled all over with it. I never got around to installing electric in the 18 years we had it. I did clean and re-lube the wiper motor a couple times though. | | | | | Joined: Jan 2016 Posts: 709 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 709 | I also rebuilt my motor using Tico's pics as a guide. Used some lithium grease and it goes great. Pretty simple too. | | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | Ficken Wiper Service will rebuild vacuum motors to perform better than new: http://www.wiperman.com/.
1951 Chevy Panel Truck
