1 members (Hotrod Lincoln),
55
Mod | | | Forums66 Topics128,090 Posts1,056,376 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | HI Stovebolters
I am currently debating on switching my current 1985 K5 Chevy Blazer rear end with 4.10 gears with a more modern Chevy Colorado rear end with 3.42 gears in it. With the 4.10's hooked behind the current stock 4 speed (sm420 ?? I think) my first gear is a granny gear....second gear is like a normal 1 st gear and 3rd and 4th gears are like the normal 2nd and 3rd gear is in today vehicles. I know from a high end aspect the the lower the number in the rear end will result in a higher top end with lower rpm's in the end.
So will the 3.42's make the 1st and 2nd gear's a little more user friendly??? or will it make harder to use???
Any insight would be a wonderful thing.
MikeC 1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | The taller gears (3.42 is "taller" than 4.10) will make it slower off the line. It might make it a little more user friendly, but I wouldn't think it would be a considerable difference. Why not just get 3.42's for your current rear end? If you change to the Colorado your brakes are different again, you have to worry about mounting and all that... Seems like not the best way to make the change.
Is there a reason you want to use the Colorado? The width of the rear end is also narrower than the K5.
I know that you've been having frustrations with your truck, I don't think this is the right way for you to get taller gears. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It will make a much better driver out of it. All gears will be higher ratio but you have the granny 1st gear for rock crawling. If it is 4 wheel drive you will have to replace both axles. The manual 4 speed in that will be a SM 465.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | I had 3.42 gears in my 59 Suburban with a 350/SM465 and 31x10.10-15 tires. It was very driveable. I only used granny as a granny and could go down the road 90mph+ if I decided to. You will still only user granny every now and then. | | |
