1 members (Gray_Ghost), 79 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#1169523 06/15/2016 5:02 AM
Replaced master cylinder on 1948 1/2 ton ,original cylinder, what kind
Of fluid should I use,how many dots fluid should l use, dos it matter?thanks
oldchevyguy #1169536 06/15/2016 12:21 PM
I recently rebuilt my master cylinder on a 54 1/2 ton. I didn't think to ask this question. I just put the basic Dot 3 in it. That was about 2 months ago. So far so good. Fingers crossed and hope Dot 3 is the right answer.
Dave from Northern Kentucky
My 54 3100
oldchevyguy #1169592 06/15/2016 7:55 PM
DOT 3 is the same as the OEM fill. DOT 4 and DOT 5.1 will also work fine, the primary difference being the boiling point. You will want to stay away from DOT 5, which is a silicone based fluid that is not compatible with the DOT 3/4/5.1 glycol based.
Bill Burmeister
