| | | Forums66 Topics128,031 Posts1,055,436 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Have a 1946 2 ton truck that I am currently doing engine work on. I want to make sure the engine is a 1946 235. If not then what year and what engine is it.
Stamped on the block just back of the distributor is: DEA558832
On the top of the head is stamped: 839491 A207 CONV 13 or Maybe CONY 13.
Thank you. Jeffrey | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Look to the front of the distributor, there should be raised numbers cast into the block not stamped. Then go to the casting numbers thread on this page, you can find the block and head there.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | It looks like the head number used on the low pressure 235 block from 41 - 48 was 839401.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | DEA = 1946 235. Mike B  | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | DEA = 1946 235. Mike B  Thanks. Jeffrey | | |
