2 members (carbking, TUTS 59), 108 guests, and 2 robots.
Topics128,029
Posts1,055,416
Members48,422
Have a 1946 2 ton truck that I am currently doing engine work on. I want to make sure the engine is a 1946 235. If not then what year and what engine is it.
Stamped on the block just back of the distributor is: DEA558832
On the top of the head is stamped: 839491 A207
CONV 13 or Maybe CONY 13.
Thank you. Jeffrey
Look to the front of the distributor, there should be raised numbers cast into the block not stamped. Then go to the casting numbers thread on this page, you can find the block and head there.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
It looks like the head number used on the low pressure 235 block from 41 - 48 was 839401.
1946 1-ton Panel
DEA = 1946 235.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Originally Posted by Mike B
DEA = 1946 235.
Mike B smile
Thanks. Jeffrey
