| | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 62 | Looking for advice/opinions on what YOU use to restore dried and cracked window gasket rubber. In 2001, I bought rear window gaskets from Steele for my panel truck and while taping them for a repaint (yes, I took all that advice and am keeping the truck) I noticed that they had started to crack in the corner bends. I sure would like to try to restore the rubber but there are so many products on the shelves I'm not sure where to spend my $. Suggestions as to something that works? | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Sorry, but I would buy some new stuff..Other than that, soak them in some brake fluid and leave them alone for awhile..good luck, Steve | | | | | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | Good old Zippo Lighter fluid might also work. It contains Naptha which causes rubber to swell. Once it swells then the brake fluid will help to preserve it.
BTW, I use Zippo fluid to clean and condition my wiper blades. Regular use can extend their life X 3. | | |
