1 members (baldeagle),
103
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I'm just wondering what the differences are in the front sheet metal of "big bolts" vs. the 3000 series trucks.
I know from outside to outside the big trucks are 74 7/8" vs. 72 5/8".
How much longer are they? How much taller are they? Whats the wheel well opening width? Any help appreciated. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Knowing what year truck your working on would help others answer your question... Mike B  | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The room for the engine is the same in small and large trucks, same distance from radiator to firewall. The fenders bolt to the cab just the same.
The big truck fenders are different enough for larger tires fit in them, a larger wheel opening. Not sure what you're intentions are but pretty much the one advantage of the big truck fenders is to fit large wheels, 36-38" or so outside diameter works and looks good. They look funny with tires about 33" or less. Roughly speaking, your opinion/ideas of tire diameter and fender opening may differ.
I measured big and small truck fenders on the truck to the inside where the tires might rub them if an axle were too wide, or wheels stick out too far.
Small truck 68" width measured inside the front fender lip at bottom of opening, same both front and back edges. 1.5 or 2 ton AD front fenders (on the truck) 72" wide inside to inside of the lip at the bottom edge both front and rear of the wheel opening
So the big truck fenders stick out about 2" more each.
Grigg | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | On '41-'47, GM, full width fenders, while rare, do exist, the wheel openings are large, so they would look 'undernourished' with 33" or less tires as Grigg says for AD's above, but at least the tires do not stick out, whether legal or not in your part of the country.
Ed
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I'm wanting a little extra width. I had read on another site that Big bolt fenders were 3" longer. I actually found a 54/55 1st series front clip not far from here. I'm only going to use a 29-maybe 31" tire, so these may not be worthwhile. May look funny. I've seen guys widen fenders by splicing in a strip of sheet metal. I just cant bring myself to do it. Here's hint of what I'm thinking, if you're at work, turn the volume down. http://s240.photobucket.com/user/ne...mp;_suid=1465847279924032982325348451835
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | If you get the 54/54 first, I need instrument panels(two piece) , so, please keep me in mind.
Ed
| | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Not only are the fenders wider,They are Longer and Taller, as are the grill supports. The hood is the same at the cowl end,but longer overall. Once used a 2 ton rear hood brace(the piece the hinges bolt to),to replace a Rotted Out 3/4 ton brace. A Friend Got Stiffed with a BIG Truck Hood,when He needed a 3000 series. Unless You Use the ENTIRE Front Clip,It Wont Work! regards, steve sr. p.s.And Oh Yes You can scavenge Good Grill Bars from the big trucks,they are only slightly wider,but the same length.(slight diff, profile)
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Good point, it's all or nothing on the AD front flip, either use 1/2 through 1 ton or 1.5 and 2 ton. Can't mix and match between them. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Cab to axle centerline is what really concerns me. I don't want to have the wheels offset in the opening. The rest, I can deal with.[ | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Consider that the AD 3800 and 4100 use the same frame in every detail except how the bumper mounts. The leaf springs in each truck also position the axle in the same place front to back.
No problem | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Consider that the AD 3800 and 4100 use the same frame in every detail except how the bumper mounts. The leaf springs in each truck also position the axle in the same place front to back.
No problem I was looking at the 3800/4100 specs in the assembly manual this morning, that never crossed my mind. | | | | | Joined: Oct 2013 Posts: 331 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 331 | Good information here. I never realized there was this much difference. I only suspected a larger radius on the wheel opening, never suspected all the other differences.
1950 4100 - unrestored and driven weekly for almost no reason at all.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | 47-54 GMC 400, 450, and 470 series fenders are even wider than the 47-54 1 1/2, and 2 ton Chevy, and GMC fenders. | | |
