1 members (MikeE),
70
Mod | | | Forums66 Topics128,031 Posts1,055,436 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | I have a '46 Chevy that I use on the farm. When the weather is humid, the steering wheel feels like it's coated with a thin layer of mud and my hands get covered with black gunk (for lack of a better term) that needs GoJo to wash off. I'm thinking maybe to paint ti with clear lacquer, but I don't know if that will solve the problem or make matters worse. Any suggestions? Thanks | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | On one of my old tractors I sprayed the wheel with black paint and it took care of the problem. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | My '38 was the same way. My modern vehicles usually eventually get a layer of sticky yuck on them as well after a period of time. I suspect it's an accumulation of oils & dirt from hands building up. On my '38 I removed the wheel, filled a large pan with warm soapy water & used a bristle brush to clean it then painted it. So far so good. There are products on the market for cleaning hand gunk off of modern steering wheels.
| | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | I don't think it is an accumulation of oil and dirt, but rather the steering wheel material is degrading and comes off on moist hands. I would remove it, wash it with soapy water, rinse it off, allow to dry thoroughly, prime it with epoxy primer, and paint it with two coats of paint. Carl
| | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | The black gunk was the same as my '52. Since the steering wheel was all black at the time I figured the factory brown paint had worn off and the underlying plastic-like substance would decompose when wet. Plastic hadn't been invented yet had it? What did they call that stuff?
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You're probably thinking of bakelite but I don't know if that is what was used on steering wheels. The reason I say it may be hand grime is my modern steering wheels eventually get the same way on a humid day.
| | | | | Joined: Nov 2014 Posts: 623 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 623 | I had that on a steering wheel one time, and I used Goop hand cleaner. I just rubbed it on the whole thing (not sparingly), let it set about 2 minutes, used a wet soft bristle brush on it a little, then a wet rag to remove it, and finished it up with a clean towel. It actually took about 3 times since it was pretty heavy, but it all came off. The I put a leather 'lace on' steering wheel cover on it so I wouldn't have to do that again.
"When I rest, I rust" 1951 3100 5 window w/ '56 235
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I had a 1950 F 1 where the original finish on the SW was gone and it felt sticky and make my hands dirty. I just cleaned it a few times and eventually the stickiness and dirty hands were gone. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I had this same problem with the steering wheel on my 37 truck. I washed it off with lots of soap and water, soaked it and washed it even more until I was down to the real wheel material. A nice paint job after that and it has been beautiful ever since. You are looking at a steering wheel that is 70 years old - allot of hands, usually dirty hands, with a truck, have been on that wheel!
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
