8 members (Phak1, ShopRag, Mr Bailey, Woodcmiami, Otto Skorzeny, Biermann, 78buckshot, DadsFirstPickup),
87
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,147 Posts1,056,801 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 70 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 70 | Since eyebrow patches for '58 Chevy fenders haven't been made in decades, from what I understand, I bought some junkyard front fenders in pretty good shape. But like any salvage fenders I've seen, lower rear patch panels will need to be welded in. What I'm wondering about is the inner fender brace that runs top to bottom at the rear of the fender. I assume this part is welded in place and cannot be easily removed. When cutting away the rotten outer skin, is the trick to cut very shallow over the brace so as not to cut through it? I will need to replace the bottom of the brace as well, but would think you wouldn't necessarily cut the brace and fender in the same place? Also, if the entire rear brace isn't replaced how can the rotten old fender gasket be replaced?
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I was able to cut the fender and leave the brace. It sounds like you'll need to patch the brace as well. I'd proceed as you've outlined.
