2 members (TUTS 59, 1 invisible), 120 guests, and 3 robots.
Topics128,026
Posts1,055,406
Members48,422
#116887 07/12/2005 2:28 AM
My 1951 Chevy 1/2 ton has been overpainted once (very poorly)with Hunter Green. I want to restore it to the original color and have done some research. The original color is exposed in several places and looks to be Brewster Green - not the dark Forrester Green which was standard. However paint codes for 1951 do not include Brewster Green - only Seacrest (too light and too blue)and Aspen Green? I do note that Brewster Green was available for 1951 cars. My color printer does not do a good job with paint chip colors. There were a lot of Green Chevy trucks out there diring 1947-54. Anybody got some input as to the correct color? Thanks, BW
#116888 07/12/2005 3:31 AM
It looks like the factory green colors used on Chevrolet trucks in 1951 were:
Forester Green, used 1947-1952
Seacrest Green, used 1947-1952
Brewster Green was used 1936-1948 (and again in 1957)
Channel Green was used 1947-1949
Juniper Green was used 1954-1955
Ocean Green was used 1953-1955 (one list says 53-57)
Forest Green was used in 1956
I do not see Hunter Green or Aspen Green in the lists that I have.
It looks like you have two choices and, as you say, Forester Green (quite dark) is distictly different from Seacrest Green (lighter and with a little blue).
It is hard to trust old paint chips (and new pigments giving the same color as the original). Are you able to get a computer match on the places with newly exposed original paint (probably not because of the piece being the cab)?
Good luck,
Tim
#116889 07/12/2005 4:13 AM
I think the problem is you are looking at exposed paint. After 50+ years of exposure to the elements, the paint will fade. Like Tim says, you need to find a spot of paint that has not been exposed. Like under the rubber seals around the windows.
#116890 07/12/2005 2:12 PM
Another good place to look for the original color is behind the voltage regulator on the firewall.
I don't believe that Brewster Green or Aspen Green were truck colors. At least not in the period 51-54. As far as I know (which may not be much grin ) the only dark green colors available for trucks from 1951-54 were either Forester Green or Juniper Green, depending on the year. These two colors were very similar. Here's a color chart online that shows the 1951-1954 Commercial Colors .
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
#116891 07/13/2005 1:12 AM
Jeff - I took your advice and looked under the regulator. Looks like Juniper Green to me! Thanks for the help. I knew it was lighter than Forester Green, but not by too much. The 1951-54 color chart was very helpful. Bob W.
