| | | Forums66 Topics128,038 Posts1,055,585 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 46 | I am thinking about not running A/C in my 48 chevy 1/2 ton. I live in Tennessee and the weather can be humid in the summer months but I still don't want to lay out over a thousand to have A/C. I am thinking about a heater defrost units. I was wondering if anyone else had any feedback on the A/C issue or suggestions for a heater A/C unit. I do not have the original heat unit and am looking in the aftermarket for parts.
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | You can get a heat/ac unit from Lucky's Hot Rod shop in Ennis, Texas for $750. Everything brand new, not fancy, but seems to hold up well. Have one in my 37 Buick.
Evan
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Heater: Cheap. A/C: Not cheap. Cheapest way; Stock heater and old under dash A/C unit with all new system to "drive it". Must be R134 compatible.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | There are areas where spending the money is worth it. In my opinion, this is one. Check out this page, for systems made to directly fit your truck. Vintage Air Advance Design Truck AC Systems | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I also live in Tennessee and feel your pain (heat). I am interested in adding a/c to a very close to orginial '64 c10. A buddy of mine put a/c on an orginial 56 Caddy and used Vintage Air's old style under dash unit. So the car looks like someone added a/c to the car in the sixties. The compressor and stuff under the hood is all modern and R-134. That's my plan.
