| | | Forums66 Topics128,125 Posts1,056,339 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 22 New Guy | | New Guy Joined: Apr 2016 Posts: 22 | Innner fender passenger side which fastens to cab. Mine has 3 inline square holes which are almost vertical. I am assuming that at one time these square holes had some type of cage nut. Am I correct or is another type of fastener used? | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | Yep. Captive nuts. I just weld square nuts in the holes. You will want to chase the threads with a tap to clean up the scale caused by the welding. Carl
| | | | | Joined: Aug 2010 Posts: 70 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 70 | Is there a spacer between the inner fender and floorboard? | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Not on the passenger side. The ebrake setup on the driver side provides the mounting point for the left inner while the passenger bolts directly to the cab/firewall toeboard. | | | | | Joined: Aug 2010 Posts: 70 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 70 | Where can you purchase 5/16" captive nuts? | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Any Nut and Bolt supply shop should have them. | | |
