3 members (Gdads51, Peggy M, Jon G), 118 guests, and 1 robot.
Topics128,126
Posts1,056,353
Members48,441
#1168766 06/09/2016 12:42 AM
Innner fender passenger side which fastens to cab. Mine has 3 inline square holes which are almost vertical. I am assuming that at one time these square holes had some type of cage nut. Am I correct or is another type of fastener used?
Yep. Captive nuts. I just weld square nuts in the holes. You will want to chase the threads with a tap to clean up the scale caused by the welding.
Carl
Is there a spacer between the inner fender and floorboard?
Fox Offline
Not on the passenger side. The ebrake setup on the driver side provides the mounting point for the left inner while the passenger bolts directly to the cab/firewall toeboard.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Where can you purchase 5/16" captive nuts?
Fox Offline
Any Nut and Bolt supply shop should have them.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
