7 members (Gdads51, joe apple, 78buckshot, Hanks custodian, Otto Skorzeny, 1955 1 Series, Rexville48), 122 guests, and 2 robots.
Topics128,070
Posts1,055,896
Members48,428
Sorry, if this was addressed previously. I searched and couldn't find an answer. So I have an original radio in my 1953 and the knobs are very loos on the pot shafts. They are repro knobs and I'm wondering if that's the issue. I don't know where they came from. Anyone else have this issue? Where do you get your radio knobs from?
mattcorad5150,
Got my repo radio knobs from Jim Carter truck parts. They were loose also. Inside the knobs are some small metal clips. I used a pick on the flat side of the knob hole and carefully bent the metal clip up toward the hole in the knob. That tightened the knob up on the shaft. Be careful not to break the plastic.
Tim
1970 VW Beetle
Great suggestion, I'll check that out. Thanks!
you could put just a little (a little) silicon caulk in the knob hole. It will hold the knob on when it sets yet will allow you to pull the knob off if needed.
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
Moderated by  ndkid275, Phak1
