3 members (ShopRag, Jon G, 1 invisible),
95
Mod | | | Forums66 Topics128,258 Posts1,058,333 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | On our 66 Suburban, I am replacing the bushings in the control arms and tracking arm. The bushings I took out have no outer metal sleeve, but the new ones that I have found so far do. These old bushings look to have been in there for a long time, chances original. Do they not make the original replacement bushings now, or should there be a metal sleeve in there? Any help is very much appreciated, thank you. | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I have not seen control arm bushings without an outer metal sleeve. So I can not say for sure that they never ever made them that way.
My first thought is that on the old control arm bushings the rubber separated from the outer metal sleeves and that the metal sleeves are still in the control arms. Jeffrey | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The metal outer sleeve may still be in the control arm. The replacements are just like the originals. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | Yes, by looking at the manual and so forth, I have determined that the bushings in the Control Arms were there originally, and they were still in the arms to be taken out. The main question I guess, is the one in the sway / pan hard bar. There was definitely no bushing in it on either end, and when I checked at the local flap, it mentioned the number and that it also may require some machining. All of the ones that I have seen new, have the bushing on the outside. I have ordered bushings from an old truck part supplier, hoping to get the correct one, but they have not shown up yet. | | |
