3 members (Hotrod Lincoln, Wally / Montana, Southerntruck), 72 guests, and 2 robots.
Topics128,060
Posts1,055,831
#116861 07/11/2005 3:22 AM
I am a novice at autobody repair. I would like to remove the bed and rear fenders in order to replace the bed wood and completely repair the fenders.
Unfortunately, I also have 50 years of rust on each bolt and nut. Does anyone have any ideas or methods on how I can remove the bolts and also save my arms and knuckles at the same time?
Thanks for your help.
Mark
1956 Chevy 3200, 1/2 Ton, 235 CI
https://photos.app.goo.gl/TQQo1YnFjs3U7xB57
#116862 07/11/2005 3:35 PM
You can soak them with a penetrating oil like PB Blaster or, if they are really bad a 4" grinder with a cut off wheel does a great job of cutting off the nut or bolt head. Just be careful not to knick areas you don't plan to do body work on.
#116863 07/11/2005 4:19 PM
the cutting wheel is the thing, but if ya don't have a grinder, and since you're not reusing the bolts, try tightening them till they break, instead of loosening them till they break - saves time grin
#116864 07/11/2005 6:23 PM
I have used a grinder and the over-tightening methods. I prefer the over-tightening method. it takes less time and less wear and tear on my grinder.
Phil
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
#116865 07/11/2005 6:25 PM
Smoke wrench is my favorite. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#116866 07/11/2005 9:06 PM
Sounds good. Thanks for your help. Best regards.
Mark
#116867 07/12/2005 7:02 AM
grinder and sawsall worked for me did 3 or 4 a day so i didnt get burn out
#116868 07/13/2005 12:54 AM
I
I Offline
I broke off my running board bolts. Wear gloves.
Don't you know who I think I am?
I've been thinkin' about freaking out. If I could just find the time.
http://community.webshots.com/user/ifrizlfri
