4 members (Hotrod Lincoln, 1955 1 Series, Thomaslb, 52Carl), 44 guests, and 2 robots.
Topics128,090
Posts1,056,028
Members48,432
#1168629 06/08/2016 12:53 AM
Best spark plugs for a 58' 235 engine?
Sean e #1168643 06/08/2016 2:18 AM
H Online: Content
AC R-45. If you can find commercial-rated CR-45's they're much longer lasting, but they are extremely hard to locate.
Sean e #1168647 06/08/2016 2:39 AM
AC C42-1 commercial was the 1958 spec'd plug.
I use R-43 or R-44 or R-45
Sean e #1168651 06/08/2016 2:46 AM
H Online: Content
The 42's will be a bit too cold, unless the engine is running full throttle with a heavy load all the time. As the numbers get larger, the heat range goes up. Back when a wide variety of heat ranges was available, the general rule of thumb was 43 for mostly highway driving, 44 for town and country, and 45 for short trips and stop and go city driving. 43 and 44 plugs are getting nearly impossible to find.
Sean e #1168654 06/08/2016 3:11 AM
Riding in the Passing Lane
The extended tip plugs are a great improvement on overhead valve engines. Like r45s or r44s in AC plugs.
1972 Chevy c10 Cheyenne Super
Sean e #1168664 06/08/2016 4:17 AM
Thanks fellas!!
