1 members (CuzzFuzz), 228 guests, and 6 robots.
Topics128,101
Posts1,056,181
Members48,436
I recently bought a nice Dodge Dakota second row seat from the pull apart yard. I want to mount this seat in my 48 Chevy 5 window 1/2 ton truck. I only paid 30 dollars for the seat and order 2 pair of universal seat mounts from Yogis. My question is that the Dakota send row seat original sat on a hump and the support on the bottom of the seat is limited. The seat folds forward when levers are lifted. My plans are to use a piece of 3/4 inch plywood on top of seat risers to mount seat to risers before mounting seat in truck. I was wondering if anyone had completed a project similar. When I did my floorboard repair we cut out the seat risers because we felt that a modern seat would not only save on upholstery cost but also provide my clearance between the steering wheel and my stomach. Any help will be greatly appreciated.
Hey 48CTD: I did something similar to my 3100. Used the 3rd seat from a mid 90s Ford Windstar ($50 brand new take out still had the plastic on it). I too cut out the original pedestal, leaving that 4" riser just forward of the gas tank (took the gas tank out of the cab too...like your 48). Anyway, the seat bottom was just not firm enough so what Idid was sandwiched a piece of 1/4" MDF between the upholstery springs at the bottom and the foam above....made a big difference! . Built my own 2 pedestals from treated 4x4s which I wrapped in the same carpet that I used on the floor. Also I made a paper template of the floor and transferred that to a sheet of 1/8" aluminum but before I bolted everything down I first filled that depression in the floor w expandable urethane foam. My entire floor is now flat, insulated and carpeted. Engineered a power seat mechanism from a 90 Park Avenue to it also. Lots of jackology but I love the bench seat, very comfortable and can seat 3 normal people easily. Hope that helps....Dave.
1948 5-window 3100 Chevy
327 V-8 TBI 700R4 Posi 3.73
"Old Blue"
More pix on Flickr
(Addendum: although my truck is titled as a 48 my cab is actually 1950).
"Old Blue"
More pix on Flickr
Moderated by  ndkid275, Phak1
