4 members (1955 1 Series, Ole49GMC, Otto Skorzeny, DaveV), 95 guests, and 0 robots.
Topics128,115
Posts1,056,294
Members48,439
Is there a cotter key hole on the end of the stearing shaft that the pitman arm attached too? 51 Chevy 1/2 ton. Thanks
No, it's a tapered spline so just a nut and lock washer.
Evan
coilover is correct - no pin, I just finished rebuild my steering box and removing the arm was simple once I got the nut off. I used a pitman arm puller similar to the one Orielly's sells, #W142.
Ron - - Dusty53
1954 Chevy 3604
