2 members (Hotrod Lincoln, Shade Baby), 66 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
The upper shock mounts for the replacement tube shocks on my 1949 GMC 1/2T p.u. only rise 1" or 1-1/4" above the frame. They came from the catalog as standard. There's about 11-1/2" between the upper and lower mounts. The shortest shock NAPA had wouldn't compress enough to fit, let alone provide travel.
What kind of shocks should I be looking for and who carries them?
Never start vast projects with half vast ideas.
Im not sure if you have some extraordinary situation going on, but I got mine for my 52 from Chevy Duty, They fit fine!
Maybe I'm missing something, but from what I understand the '49 is a single action lever type shock. Sounds like somewhere along the way someone converted the original type to tube type. Probably because of cost. Cecil.......
I'm moving this to Engine and Driveline where you will get more visibilty.
Paint & Body Shop moderator
