5 members (Cosmo, Otto Skorzeny, Bwana-Jim, J Lucas, Hotrod Lincoln), 98 guests, and 1 robot.
Topics128,036
Posts1,055,450
Members48,422
#1168186 06/04/2016 11:56 PM
What is the best way to remove old gasket residue from the engine. Is it a plastic scraper? A razor blade? I'm replacing my water pump and thermostat on my '41 235 and don't want to screw something up?
Andy
Sometimes you're the window
Sometimes you're the bug
TK421 #1168188 06/05/2016 12:18 AM
try a plastic scraper first, if that don't work I us a putty knife. root
TK421 #1168192 06/05/2016 12:35 AM
Care to prevent gouging metal and any method should work. So take your time. Just keep the scraping tool edge parallel to the work surface so the scraping tool corners do not get a chance to dig into the part surface to prevent making gouges. Also keep the angle of the scraper low to the work surface to have better control.
Wire wheel in hand drill, scotch pad in a hand drill are other options. As well as a single edge razor blade, sand paper on a sanding block, and spray on gasket remover that helps to soften up the old gasket and makes it easier to scrape off.
32vld #1168428 06/06/2016 5:13 PM
Pump coming today. Anything I should be aware of before I start? I bought some Prestone radiator cleaner and plan on running that through. Anything else. Was planning on using Orange anti-freeze
TK421 #1168457 06/06/2016 9:56 PM
I would advise against using the orange antifreeze. It is intended for late model GM vehicles, and can cause issues with older vehicles, primarily damage to the head gasket (it causes that problem even in engines it's meant to go in), as well as potential chemical reactions with any green antifreeze that may be left in the system. I would suggest using one of the "mix with any" antifreezes that are on the market, Those will be just fine in it. I would also suggest it for replacement in late model GM vehicles, but only a very thorough flushing to remove any traces of the orange antifreeze.
Bill Burmeister
TK421 #1168467 06/06/2016 11:37 PM
I use green in the 1946.
32vld #1168493 06/07/2016 2:13 AM
Green traditional too
TK421 #1168563 06/07/2016 4:20 PM
Use regular green antifreeze. Only use Dexron (orange) when the vehicle needs it.
Scrape the gasket with a metal putty knife or if it's really stubborn use a razor blade. Use a low angle, and not much force.
My 46 GMC on Photobucket
TK421 #1168580 06/07/2016 6:35 PM
Lacquer thinner softens up the old gasket and you can get it off with plastic scraper after about 5 minutes.
One thing though - the old gasket will be "gummy" so keep a couple of rough shop rags nearby.
TK421 #1168595 06/07/2016 8:06 PM
Sir Searchalot
Sir Searchalot
Non destructive: Wire wheel, razor blade. Correct angle of blade is important so as not to gouge. Very good point by 46GMC. Plastic blades can't do the job.
TK421 #1168714 06/08/2016 4:29 PM
Good advice here, the Orange was intended for all aluminum engines, but as correctly pointed out it caused problems.
Stick with the green coolant. About two years ago the government mandated a change to non-toxic antifreeze mainly because of pets drinking up the sweet stuff that may be spilled or dripped.
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine
4 1966 Plymouth VIP 5.7 GenIII Hemi
5 1966 Imperial Crown Coupe 440 engine
TK421 #1168788 06/10/2016 4:00 AM
Got it all done, put distilled water in it and ran it for a while till it got up to temp. No leaks 😀 There is a lot of rust and sediment in the system, at least what I can see. What's the best way or product to clean it all out?
Also, I have noticed the exhaust manafold smokes a bit. Any ideas?
