| | | Forums66 Topics128,021 Posts1,055,372 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | What is the best way to remove old gasket residue from the engine. Is it a plastic scraper? A razor blade? I'm replacing my water pump and thermostat on my '41 235 and don't want to screw something up?
Thanks Andy
Sometimes you're the window Sometimes you're the bug
| | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | try a plastic scraper first, if that don't work I us a putty knife. root | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Care to prevent gouging metal and any method should work. So take your time. Just keep the scraping tool edge parallel to the work surface so the scraping tool corners do not get a chance to dig into the part surface to prevent making gouges. Also keep the angle of the scraper low to the work surface to have better control.
Wire wheel in hand drill, scotch pad in a hand drill are other options. As well as a single edge razor blade, sand paper on a sanding block, and spray on gasket remover that helps to soften up the old gasket and makes it easier to scrape off. | | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Pump coming today. Anything I should be aware of before I start? I bought some Prestone radiator cleaner and plan on running that through. Anything else. Was planning on using Orange anti-freeze
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Was planning on using Orange anti-freeze I would advise against using the orange antifreeze. It is intended for late model GM vehicles, and can cause issues with older vehicles, primarily damage to the head gasket (it causes that problem even in engines it's meant to go in), as well as potential chemical reactions with any green antifreeze that may be left in the system. I would suggest using one of the "mix with any" antifreezes that are on the market, Those will be just fine in it. I would also suggest it for replacement in late model GM vehicles, but only a very thorough flushing to remove any traces of the orange antifreeze.
Bill Burmeister | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Use regular green antifreeze. Only use Dexron (orange) when the vehicle needs it.
Scrape the gasket with a metal putty knife or if it's really stubborn use a razor blade. Use a low angle, and not much force. | | | | | Joined: Apr 2006 Posts: 273 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 273 | Lacquer thinner softens up the old gasket and you can get it off with plastic scraper after about 5 minutes. One thing though - the old gasket will be "gummy" so keep a couple of rough shop rags nearby.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Non destructive: Wire wheel, razor blade. Correct angle of blade is important so as not to gouge. Very good point by 46GMC. Plastic blades can't do the job.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2011 Posts: 131 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 131 | Good advice here, the Orange was intended for all aluminum engines, but as correctly pointed out it caused problems. Stick with the green coolant. About two years ago the government mandated a change to non-toxic antifreeze mainly because of pets drinking up the sweet stuff that may be spilled or dripped.
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine 4 1966 Plymouth VIP 5.7 GenIII Hemi 5 1966 Imperial Crown Coupe 440 engine | | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Got it all done, put distilled water in it and ran it for a while till it got up to temp. No leaks 😀 There is a lot of rust and sediment in the system, at least what I can see. What's the best way or product to clean it all out? Also, I have noticed the exhaust manafold smokes a bit. Any ideas?
