6 members (Hotrod Lincoln, Peggy M, Otto Skorzeny, DadsFirstPickup, dinosoar, Robert Crandall), 120 guests, and 2 robots.
Topics128,127
Posts1,056,675
Members48,450
Apprentice
Apprentice
do they make new hinges for 52 gmc pickup doors all i see in the magazines are replacement clips for the doors i suppose if thats what it takes to fix the problem of sagging doors great then i removed the foot starter from this vehicle when a engine swap was done and replacing the accelorator pedal in the process is there a rubber gasket out there to cover this hole so i dont always smell of v8 colone thanks for your help
not sure on the hinges, but Chevy would be the same if you haven't checked that way - the starter hole plug wasn't much used before they invented a different way to start the engine, so no factory original to reproduce, but if you look someplace that has a good array of electrical supplies, there are a range of 'blank out plugs' for electrical boxes and one of those should fit - just silicone it in and put the mat over it and no one will ever know grin
You can get your hinges rebuilt. I had mine done by Ray Stanely at Wheelright Restorations and they are as good as new.
1951 1 Ton Completed
