| | | Forums66 Topics128,147 Posts1,056,798 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | I came across a '40's truck in a yard today and it had an engine with a 1 bbl Rochester carb on it. Surprisingly, the carb still had a tag on it. The fella with me read the numbers 70024675 (could've been a 1 instead of a 7). It also had K2 on the tag. I've tried looking this up on google, but no luck. Can anybody cipher the numbers? I didn't think to get the eng cast number.
1959 3100 Apache Fleetside
| | | | | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | Rochester tag numbers should be 7 digits, not 8.
Probably a "service replacement" if on a 1940's truck. When Chevrolet downgraded from the Carter to the Rochester in 1950, the new parts books showed a service replacement for vehicles back to 1932.
Jon.
Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | Thanks Jon.
Maybe there is one too many 0's. Next time I am up there I'll check the numbers to be sure.
