3 members (Materman, blanch53, 1 invisible),
125
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2014 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: May 2014 Posts: 44 | I am rebuilding the brakes on my 51 3100. The spring anchor stud has a couple of flats machined on each side to create an oblong. This matches the opening in the backing plate. There is also a matching washer or spacer with the oblong opening. My question is: does the spacer go inside the backing plate or outside the backing plate? I think inside but I am hoping one of you knows for sure. Thanks for your help! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | front or rear? here is the front The rear is almost the same - there is a parking brake lever attached to one shoe on each rear side. | | | | | Joined: Mar 2016 Posts: 225 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 225 | If you are talking about the anchor pin right above the wheel cylinder, (and that's what it sounds like), you have a thick washer with the center hole having a flats on two sides. This washer goes on the OUTSIDE of the backing plate. If you try to install this washer on the inside, the anchor pin flats I don't think will reach the backing plate, which allows it to turn, which you don't want. Once you install the anchor pin, there is enough shaft that comes through the backing plate for the washer to slide upon. I always do one side at a time, start to finish. That way, when the mind slips (and I hope I'm not alone on this mind slipping deal), I have a template on the other side to go by.
Mike
Mike
1951 3100 5 window
| | | | | Joined: May 2014 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: May 2014 Posts: 44 | That is exactly what I am talking about. Thanks so much! | | |
