2 members (SNOYL, Otto Skorzeny), 119 guests, and 1 robot.
Topics128,080
Posts1,056,063
Members48,433
#11676 10/11/2003 9:01 PM
I can't find my old flywheel bolts so I bought some new ones. I don't remember any lock plates when I took the flywheel off.
I've read some posts that the lock plates are hard to come by and that people just use Locktite Red. Is that what I should do?
Thanks!!
Hi Wally
You could use some mild steel sheet metal and make some lock plates or the quicker way will be Locktide. Locktide will make it harder if you want to remove the flywheel and reinstall it. It leaves some gum in the old thread.
Fritz Peyerl
Turner valley, Alberta
http://www.badmileage.com
Basically all your later model flywheel instalations use a star whasher to prevent the bolt from backing out. Thats what I have always used in stock 6 cyl. and drag racing for years and never had a problem. I torque all the bolts and apply a dab of paint or finger nail polish to each bolt to see if they do back out, like I say never a problem. grin
Red loctite is highly recommended. And it's not that hard to remove, just hit the bolt head with a propane torch. grin
Fred
52 3600
69 C-10
I made my own lock plates with a tin shingle like the roofers use to flash with around chimneys. It's galvanized sheet metal about 5" x 8" in size and since it's galvanized, it won't rust. You can buy them at Home Depot, Lowe's, Truevalue or Ace. Ask for a tin shingle. You can cut it to the size you want with tin snips. There are three pieces used on a flywheel, two bolts on each piece. Just torque down and bend up the corners. It is the safest way to go. Your bolts WILL NOT COME LOOSE with lock plates until you take the bolt loose.
