4 members (68ironhead, Wayne67vert, GRNHydra, Oswald), 131 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
#1167715 06/01/2016 2:13 AM
what is the best way to fill holes ( dime sized ) in my 53 1/2 dash? http://s651.photobucket.com/user/Sc...72741%20dash%20holes_zpspfcauyyo.jpg.htm They are the two holes next to where the radio fits. The two outside holes are for the dials. Thanks, Scott
scottss60 #1167717 06/01/2016 2:33 AM
Gas Pumper
Gas Pumper
A correct gauge patch is what I do. A washer with a smaller hole then weld it closed will do. I cut a small piece of metal and butt weld it in, then grind everything smooth. A dime size hole is small enough to actually fill it in with weld if you are good.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Deve #1167744 06/01/2016 5:26 AM
In any case, (good or not so good) a copper backer bar helps quite a bit for filling holes.
(Happy Birthday, Deve chug)
scottss60 #1167958 06/03/2016 1:19 AM
Saw a "magnetic copper backer" from Eastwood on Youtube that looks promising... what kind of welder would I use? Deve, what do you mean by "correct gauge patch" and where do I find them? Will google it.. thanks, for the input.. I was thinking of Bondo or some some kind of fiberglass patch/filler. Thanks,
Scott
scottss60 #1167960 06/03/2016 1:42 AM
Scott
Here's what I got. http://www.amazon.com/Durston-Manuf...true&ref_=oh_aui_detailpage_o08_s00. It's probably about the same as Eastwood would sell, but for less money. The only issue I have had with it is if there's lots of curvature in the panel, it's sometimes tough to get the pad flat against where you're welding. There are others that are a slab of copper with a handle attached, but you usually need a third hand to use one of those. You could make one of those from a piece of copper pipe that you flatten with a hammer. Copper pipe is available at about any hardware store or plumbing shop.
By "correct gauge" Deve meant cutting a patch from a piece of sheet metal of the proper (matching) thickness. A MIG or TIG welder works best for welding light metal. Bondo/Fiberglass would a less preferable option, IMO.
scottss60 #1167961 06/03/2016 1:50 AM
Gas Pumper
Gas Pumper
Yup. Really any piece of metal that is close would do. Part of an old fender, or just about anything can serve as a patch as long as the metals are the same for welding. I use this for the copper backing when I can:
http://www.harborfreight.com/welding-spoon-66785.html
Any piece of copper will do. Of course, if you don't have a piece of copper, just hold the piece to the hole with vise grips or something, tack it in place, then finish.
Deve
The Think Tank
scottss60 #1167975 06/03/2016 3:22 AM
Wow, great advice... since this is not something that I see myself doing after these two hole, any recommendation for a "cheap" welder to do this job? Thanks, Scott
scottss60 #1167977 06/03/2016 3:32 AM
Gas Pumper
Gas Pumper
no! A cheap welder is a waste of money. If it costs you $300 or more for the welder, just take it to a welding shop and have them do it. You get a professional job and you don't have some junk tool lying around. MHO
Deve
The Think Tank
Deve #1167983 06/03/2016 5:10 AM
Agree 100%.
I had a cheapo flux core welder that I sold off when I started this project. The old one wasn't good for much more than putting bird $#!^ on metal.
Even if you bought a decent MIG setup, that wouldn't be the first job I'd tackle anyway.
scottss60 #1168187 06/05/2016 12:08 AM
I am going to borrow a friends Mig welder and after a tutorial and practice will fill those holes referenced above. Any recommendation as to kind of "filler material" I would use? Thanks, Scott
scottss60 #1168197 06/05/2016 1:13 AM
Gas Pumper
Gas Pumper
Just the wire that comes out of the MIG wand. Your friend would probably have it loaded. DO practice. In this case very low setting with medium wire speed. It is very easy to blow holes in your dash instead of fixing it.
Deve
The Think Tank
scottss60 #1168198 06/05/2016 1:29 AM
just take your time, and KEEP IT COOL!!!!!! if it's too hot to touch, then it's too hot to weld. also, do small tack welds, not one continuous weld, it may take a little more time, but the results will be worth your extra effort.
Richard wink
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
scottss60 #1168199 06/05/2016 1:37 AM
If you have an unrestorable fender laying around, you could use a piece of that.
Another handy tool is a welder's magnet Like these It will hold your plug in place till you get it tack welded.
If you're talking filler metal for the welder, you want steel wire of course. Your buddy should have the right stuff.
scottss60 #1168667 06/08/2016 4:34 AM
Thanks for all the advice. At this point, I will see if epoxy putty will do the job. Will update.
scottss60 #1169561 06/15/2016 4:07 PM
Epoxy putty seems to have worked great. AFter one hour, was able to sand and cut it with Dremel tool. Paint today.
