3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1167729 06/01/2016 3:49 AM
Big Bolt Forum Moderator
The transmission in my 58 2-ton is slipping out of 2nd gear. I am looking for a replacement (assuming I have some parts worn that are not included in a master rebuild kit) My question is, does the SM420 case out of a 1/2 ton have all the mounts for the park brake setup, or was there a difference in the case used on the different tonnage trucks? (I am assuming they are all the same case, and I can just replace the rear yoke with my park brake hub and yoke and bolt the rest of the linkage up.
Mike
Mike,
There are different Main Case casting numbers throughtout the life of the SM-420 that I can't explain. Could be when internal bearings changed sizes or if they added a threaded bolt hole for a bracket...who knows?
That said it looks like the rear bearing retainer should bolt on to the same vintage case...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
