2 members (Peggy M, panic),
89
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | Just recently installed a digital LED voltmeter. I hooked it up to the (anti theft) kill switch wire to my coil, on my 55 2nd pickup. It reads 8.5 volts when the ignition is on and 9.5 when engine is running. I assume it is showing the voltage from the resistor to the coil. My normal voltmeter shows 14+/- volts when engine is running. Could this digital meter be used to indicate any problems or defective ignition points, coil, etc?
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Is your 'normal' voltmeter also digital? If not it may have something to do with digital sampling rate and/or the hysteresis of an analog meter. Just a guess. Maybe elevated ground?
| | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | No, my voltmeter is analog and shows battery voltage when ignition is on and alternator output when engine is running. I hooked up the new digital gauge to the coil kill switch wire, not thinking of the resistor voltage drop. Kind of cool to see the primary voltage to the coil. Just wondered if it could be used to indicate any electrical problems. The truck is running great! | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Are you speaking about the voltmeter mounted in the instrument cluster or an external one you might troubleshoot with. The cluster mounted gauge measures system voltage and unless input is changed doesn't measure coil voltage. As far as a trouble indicator goes, it might help you see something like ballast resistor failure, condenser failure or something of that order. Truth is, the engine will let you know a problem is occurring around the same time. If the LED display turns your crank, then go for it.
