0 members (), 171 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
#1167447 05/30/2016 4:03 AM
Trying to find out what year my rear axle is is there any markings on the rear axle any were to determine the year. The truck I took it out of I beleave is a 52. The truck had push button door handles tube shocks. Ordered a ring and pinion kit and wanted to make sure I got the right Oakley bushing as I think they were different size bushings for different years.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
KEVINSKI #1167467 05/30/2016 12:23 PM
On the Chevy truck there is a s/n on the driveshaft side of the pumpkin. It's stamped in and it will be on the left when looking from the front of the truck. If it starts with a K it's a 52
Just so you know the bolt circle diameter on Canadian carriers is different than in the US so modifications are required to make it fit. More info
You Tube
Thanks I was aware of the carrier being different and have one on order just wanted to make sure I had the right oakie bushing as my 54 truck has a older rear end in it . I will check the number on the axle.great imfo thanks again
"The Journey"
Follow in the DITY
