| | | Forums66 Topics128,139 Posts1,056,454 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 2,316 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,316 | Trying to find out what year my rear axle is is there any markings on the rear axle any were to determine the year. The truck I took it out of I beleave is a 52. The truck had push button door handles tube shocks. Ordered a ring and pinion kit and wanted to make sure I got the right Oakley bushing as I think they were different size bushings for different years.
| | | | | Joined: Apr 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 54 | On the Chevy truck there is a s/n on the driveshaft side of the pumpkin. It's stamped in and it will be on the left when looking from the front of the truck. If it starts with a K it's a 52 | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Just so you know the bolt circle diameter on Canadian carriers is different than in the US so modifications are required to make it fit. More info
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2010 Posts: 2,316 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,316 | Thanks I was aware of the carrier being different and have one on order just wanted to make sure I had the right oakie bushing as my 54 truck has a older rear end in it . I will check the number on the axle.great imfo thanks again | | |
