1 members (1 invisible),
116
Mod | | | Forums66 Topics128,193 Posts1,057,258 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Hi all- I just replace the rear brake cylinder on Big Red. When I went to put the drum back on it was almost impossible to turn. It would turn, just a lot of effort. Any ideas what may be causing this? Second question I figured while I had the rear drum off I would look at the bearings. first thing I found was the previous owner had pressed the seal back in and used some lock tite to keep it in. (it has been rough weekend and kinda took my frustrations out on the seal.) Now that it's trashed I need to get a new on. On inspecting the bearing It was very low on grease. It also had some play in it. Is the play ok, if the bearing is on the axel the movement would be in and out along the axel.
Thanks in advance
Andy
Sometimes you're the window Sometimes you're the bug
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I do not know about your truck though there is no grease for the rear bearings. The gear oil in the differential/rear end gets splashed/thrown down the axle tubes onto the axle bearings for lubrication.
Did you match up the new wheel cylinder to the old one before you put it on the truck?
If your truck is like mine the ends of the wheel cylinder are where the brake adjustments are made. Your new wheel cylinder most likely has the adjusters turned out farther then the adjusters on the old wheel cylinders.
Pull drum check if all parts are installed correct, then back off the brake adjusters and put on drum then readjust the brakes. Jeffrey
| | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Manual recommends greasing bearings lightly before reassembly to protect them until gear oil makes it from the pumpkin. Make sure the drum/hub is fully seated if not it may be slightly off center causing drag. If you over tighten the axle nuts it will keep the wheel from turning freely.
