1 members (DES57), 119 guests, and 3 robots.
Topics128,193
Posts1,057,257
Members48,466
I think I saw something about this not long ago but is there a translation somewhere for the numbers in the shop manual that pertains to specific nuts and bolts? i.e. Brake pedal and main cylinder instruction sec 5 sheet 2.00/ under the part that says pedal shaft, 106291 bolt
103322 lw (lock washer)
271505 nut
Other than part numbers what do the number correlate to an in size?
Joe
U
U Offline
Joe, you can look in the Master Parts Catalog from Keith Hardy's site, find a part number to a part you have (in hand), measure it & see if it correlates somehow (?).
It's a good question, but I've never noticed any correlation between part number & size. The numbers do link to a "family" or "group" within the system as a whole, however.
Brad
Wrench Fetcher, PhD
Thank you brad
