| | | Forums66 Topics128,193 Posts1,057,241 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | I think I saw something about this not long ago but is there a translation somewhere for the numbers in the shop manual that pertains to specific nuts and bolts? i.e. Brake pedal and main cylinder instruction sec 5 sheet 2.00/ under the part that says pedal shaft, 106291 bolt 103322 lw (lock washer) 271505 nut Other than part numbers what do the number correlate to an in size?
Joe | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Joe, you can look in the Master Parts Catalog from Keith Hardy's site, find a part number to a part you have (in hand), measure it & see if it correlates somehow (?). It's a good question, but I've never noticed any correlation between part number & size. The numbers do link to a "family" or "group" within the system as a whole, however. Brad Wrench Fetcher, PhD | | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | | | |
