| | | Forums66 Topics128,050 Posts1,055,757 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 31 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 31 | Has anyone a trick for installing the king pin cap on the bottom of the axle? | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Clean the groove out squeaky clean. Sometimes there are places around the rim of the hole where they have been staked (mashed, as we say round chere). You will need to fix those areas. Put the cap in place and strike the center with a hammer. You can stake around the rim several times with hammer and small punch if it will make you more confident in holding it in place. Carl
| | | | | Joined: Dec 2013 Posts: 784 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 784 | I was able to clean out the groove with my dremel tool. The caps fit into the groove quite nicely. Then what Carl says....... | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | That was a link to a great post, thanks. Jeffrey | | |
