2 members (lumbersawyer, klhansen), 75 guests, and 0 robots.
Topics128,047
Posts1,055,538
Members48,424
#1167065 05/26/2016 5:44 PM
I have a 3 speed on the column in my 49 3100. Before I proceed to pull it I wanted to ask some questions. Before I lost 3rd gear it would slip out mostly when I hit a bump before I totally lost it... could this be a misalignment issue? Anything I should try before I pull it? It just grinds when I try now.
1964 impala ss
1949 chevy 3100
pking75 #1167069 05/26/2016 6:15 PM
Big Bolt Forum Moderator
It almost sounds like the linkage was not adjusted properly and it was not going into 3rd all the way. I am assuming that you made sure the linkage is adjusted properly?
Mike
69Cuda #1167072 05/26/2016 6:50 PM
Yes once we installed the 235 we did
1964 impala ss
1949 chevy 3100
pking75 #1167180 05/27/2016 1:44 PM
With the engine off, shift it into 3rd (normally, don't force it)
Then crawl under and push the shift arm on the trans further into gear. If it moves, linkage isn't doing the job.
Look for oval holes, worn rods, or shifting box problems.
Other possibility is that the shifting fork is worn half through.
pking75 #1167216 05/27/2016 9:15 PM
Don't know for sure but.....can the 3rd shift fork not be turned around to get somewhat new metal against the 2nd and 3rd speed clutch ring. Mine was worn more on one side than the other. Just asking.
