1 members (Steveoreno),
111
Mod | | | Forums66 Topics128,195 Posts1,057,375 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | I have a 3 speed on the column in my 49 3100. Before I proceed to pull it I wanted to ask some questions. Before I lost 3rd gear it would slip out mostly when I hit a bump before I totally lost it... could this be a misalignment issue? Anything I should try before I pull it? It just grinds when I try now.
1964 impala ss 1949 chevy 3100
| | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | It almost sounds like the linkage was not adjusted properly and it was not going into 3rd all the way. I am assuming that you made sure the linkage is adjusted properly? | | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | Yes once we installed the 235 we did
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | With the engine off, shift it into 3rd (normally, don't force it) Then crawl under and push the shift arm on the trans further into gear. If it moves, linkage isn't doing the job. Look for oval holes, worn rods, or shifting box problems. Other possibility is that the shifting fork is worn half through. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Don't know for sure but.....can the 3rd shift fork not be turned around to get somewhat new metal against the 2nd and 3rd speed clutch ring. Mine was worn more on one side than the other. Just asking.
