5 members (Gdads51, Rich'sToys, jasrking, TooMany2count, FishinToms53), 119 guests, and 1 robot.
Topics128,126
Posts1,056,354
Members48,441
#1166622 05/23/2016 6:44 PM
Hi everyone, I have a 54 235 and plan to start it up for the first time, I see lots of discussion about engine oil for these vintage engines. What are BC Bolters using for engine oil in their trucks. any thoughts would be appreciated...Glenn
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody
Look at using an oil with ZDDP in it. It's a zinc-based anti-wear additive that helps lubricate our vintage beasts.
There are vintage specific oils you can purchase but they can be ridiculously expensive. I have heard diesel oils have the required ZDDP but you want to be sure not to get one with too high of a detergent level in it as that can be bad for the engine.
Alternatively you can buy a zddp additive. Maybe check at Lordco or your fav. parts supplier... or of course you can buy it on Ebay or Amazon.
Lucas oil for example
Can you get Valvoline VR1 up there in BC? I buy it here in Texas, though I have a tough time getting several quarts of the same weight at the same store, so I have ordered it from Amazon in a case of six to avoid having to visit multiple stores.
Hi EBS, I will check that out, thanks for the info
I think that was I used on the last change. Had to order my filter on line.
Here is a very good article concerning motor oil.
http://blog.hemmings.com/index.php/2012/10/18/tech-101-zinc-in-oil-and-its-effects-on-older-engines/
I also located the Valvoline VR1 at NAPA.
https://www.napaonline.com/p/VAR205#
Harold
Harold
Moderated by  Gord&Fran
