0 members (),
137
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Gentlemen,
I know this topic has been addressed many times, but product quality changes...
Looking for a rubber oil line kit for a Delco S-6 filter mounted on a 1958 235. I believe the two lines are 19 and 21 inches long.
Who sells the best lines at the best price today?
Paul | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | The next remote oil filter that I will do, will be with nickle/copper brake lines. Millions of tractors used steel lines without any troubles since there were no rubber lines to fail. They work because there is no movement between the engine block and the engine-mounted filter. GM did not install oil filters on their engines. It was a dealer added option. I believe that soft lines were used because it was easier for the dealer to hook it up in a hurry. I plan on adding rubber tubing which will fit on the outside of the nickle/copper line to appear as original. The nickle/copper brake line in very easy to hand bend into the proper shape. Carl
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The best set I have found is from classic parts. It includes swivel fittings & 90 degree L,s. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2008 Posts: 1,923 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,923 | soft lines were used because it was easier for the dealer to hook it up
and not having to carry specific lines for each install.
Use brake line. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Any shop that makes hydraulic lines can make them for you.
Bill Burmeister | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Carl, sometimes you are a genius. I recall the discussion a couple years ago about bending hard lines and it sounded like a fun project. The ID of a 1/4 brake line is the same as the hose and it can be routed much more safely away from the exhaust manifold. It can most likely be constructed from spare residue floating around the shop as well.
George, thanks, those did look like the best deal to me as well and I think that is what I used on my 41. | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Whenever I use hard lines for an application like a remote filter, I put a 360 degree loop somewhere in the line to act as a vibration isolator. That prevents lines from cracking or splitting flares with pressure surges. It was standard procedure for pressure gauge lines on most of the industrial equipment I worked on as a mechanical maintenance technician at places like E.& J. Gallo winery and Armstrong Tire Co. Jerry
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You know, Jerry, I have to explain that every time when I replace brake lines from a master cylinder. I always get the same question, "Why are you putting those loops in there? It's easier to just run the straight to the frame.". I've even had to redo lines from some doofus at another shop putting them in wrong and they cracked.
Bill Burmeister | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | I suppose there would be some flexing of the filter as the clamps attached to the intake manifold are not the most secure mounting arrangement.
One reason for my question on rubber lines is to inquire about the quality of the hose. I have seen material ranging from grease gun hose to non-fuel injected fuel line used. Are either of these types of hose rated for hot oil @ 50 PSI? | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | Back in the early 60's I had a 60 Chevy with a 235. One of the oil filter hoses developed a leak. I made a line from copper tubing. Flared the ends and gave it a 360 degree vibration loop. Never had a problem with it.
Rick
1939 Chevrolet Stake Truck
| | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Just finished a GMC 228 oil line redo. The stock 3 way fitting out of the front block in my case made for an interesting project. This three way goes to the head oiling , oil filter and pressure gauge.
The thread mix, fitting mix and transions in sizing in the stock pipe and then the vibration isolation rubber lines makes it challenging.
There are inverted flare fittings and transition fitting to rubber lines in the stock setup that are no longer available. I used a cobination of brake line, a rubber line and flare to get the job done. The filter threaded fitting themselves were different on the GMC from the Chev.
Found a same transition problem on the oil pressure gauge line at the fire wall. Stock is 3/16" pipe to an inverted flare to rubber line to 1/8" line to the gauge. Replaced with vibration loop with compression fittings and a coupling with 3/16" to 1/8".
[URL=http://s398.photobucket.com/user/showkey_bucket/media/image_zps00cd12uv.jpeg.html]pic of filter oil line[/url]
| | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | Can copper tubing be used instead of brake line? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Can copper tubing be used instead of brake line? Yes - it might be preferred. Copper-Nickel tubing would also work nicely. | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Soft copper has a nasty habit of cracking at flare fittings if it's not double-flared. The cupro-nickel tubing would be a better choice, since it's suitable for medium-pressure applications like hydraulic brakes. Jerry
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | While looking through some images, I noticed one of a topic I began a while back... Here is my solution of a hard line set up for the oil filter. [img]http://www.surfacezero.com/g503/data/3285/oil_lines.JPG[/img]Thought a follow-up would be nice as most ask questions but rarely post solutions.
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | | | | | | Joined: May 2013 Posts: 6 New Guy | | New Guy Joined: May 2013 Posts: 6 | An older thread, but Folks I know have used the "grease gun lines", having ends made up at NAPA. For me, I use hard lines, with a loop.
Regarding dealer installed oil filters vs factory installed oil filters, BOTH were done. If the oil filter was factory installed, under RPO 237, the canister was black, the top had white lettering on it. The dealer installed oil filters had a blue canister with an orange top. BY 1962, the 6 Cyl had a factory installed filter, as standard equipment. It was black.
| | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | Paul:
I suppose you could call that "military grade" or "mil-spec" for marketing purposes. Nice work!
Did you flare your own or buy the kind that have the fittings already installed? I'm curious what size the fittings are. My rubber lines from Jim Carter are almost a bit too short.
I might do what you did but I lack the flaring tool and might just but the pre-fab line.
1951 3100
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | Very common to loop hardline. Only need on loop, although the multi loop thing looks kinda cool. From my 1940s Cevy manual: http://i.imgur.com/ZWHg5he.jpg | | |
