3 members (NJC, Hotrod Lincoln, DoubleB), 55 guests, and 0 robots.
Topics128,090
Posts1,056,024
Members48,432
#1166587 05/23/2016 8:33 AM
Just recently changed my 1963 230 c10 to the twin 32/36 carbs purchased from Langdon Stovebolts, everything is fine until i have driven about 30 miles then its starts to splutter and dies, i reduce the speed from 50/55 down to about 40 and it will pick up again, the more miles i do the worse it gets, i can even be doing 25/30 and suddenly its cuts out but taking my foot of the accelerator, then putting it gradually down again it will pick up but sometimes splutters, going to do a 700 mile trip in July and i dont want to be stopping and starting
Sounds like one of these issues.
1. the fuel pump isn't keeping up with the demand
2. vacuum build up inside the tank - make sure the fuel tank is vented or use a vented cap
3. the fuel bowl float needs adjustment.
I suspect #1 or #2 is the problem. It take a while for the fuel tank to build up vacuum. Drive it until it sputters and then stop and pop off the fuel tank cap. If you hear suction then you may have found your problem. Especially true if you can then drive it again without sputtering for another 30 minutes.
Let's see if others agree.
Sir Searchalot
Sir Searchalot
Agree with pump or tank. Drive with cap off to test. Sometimes you think the cap is vented but it's malfunctioning. Don't two carbs take more pump volume than stock pump?
Agree it's a fuel delivery problem so...lots of other stuff besides a tank vacuum lock or pump.
4. Dirty filters
5. Pick up sock clogged
6. Out of gas
7. (no.3) Carb adjustment of all kinds, float level, etc
8. Bad rubber hose somewhere
9. Manifold Vac leak
* Timing and possibly electrical issues.
The key is the slow progression which points to Fuel Delivery. Lots of things between tank and venturi.
Test and troubleshoot and call me in the morning grin
Big Bolt Forum Moderator
When I brought my 55 2-ton home, I cleaned the fuel system out and put new gas in it. Everything was fine for a week or two then the rubber line coming out of the tank swelled up inside and would do the same thing. If I let it set for a bit, it would fire right back up, then die after a while, you may have something similar going on, especially if you are running dual carbs and pulling more fuel flow than before.
Mike
Hi-
Consider pulling the sending unit: the intake may have a screen filter which could be partly clogged causing Intermittent fuel starving.
RA
easy fix, call Tom, he will help you
Redryder pix
My Hotrod
Gents,
I checked the filler cap and that is vented.
Checked the fuel lines and as a precaution i changed them all.
Last night removed the sender unit and guess what clogged up didnt have time to take it out for a run will try tonight and update you all tomorrow.
Many thanks
