9 members (JoergK., klhansen, Hotrod Lincoln, Stovebolt48, 1955 1 Series, Bill Hanlon, fonz8261, latroca52, 1 invisible), 104 guests, and 1 robot.
Topics128,195
Posts1,057,373
Members48,469
And if it does, where is it located? I'll be danged if I can find one. Pictures would be even better. Thanks!
1946 Chevrolet 1/2-ton
More pix on Photobucket
I can get you a picture but it may be a few days. Others may give you a faster response, I will get it if no others do.
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Sometimes overlooked by mechanics and restorers is a small vent in the driver’s side rear axle housing approximately 10” from the mounting holding the springs to the housing. This part is necessary to keep internal pressure equal to the outside atmosphere. Thus, as the internal temperature of the differential warms during use, any expanding heated air is vented and no pressure occurs. This saves wheel and pinion seals from leaking.
After many years of use, many vent assemblies were accidentally removed. Now, the small hole that once held the vent assembly is able to take in water. This is certainly not good for the internal differential parts. If the cap is still present, spray under cap with PB Blaster and make sure the cap turns freely. The cap does not come off.
Harold
Rear end Vent
Harold
Awesome! Thank you so much! I will look for it as soon as I get home today.
H Online: Content
Sometimes the vent is incorporated into the bolt that holds the brake line T fitting to the axle housing.
I will take a look there as well. I looked at the rear end over the weekend and found no vent as mentioned above. While I have no doubt 'some' trucks must have come with a vented rear end, it appears mine did not. Thanks again HL, I'll take a look tonite.
Some early years had the vent half way up the torque tube, but all had a vent.
My Blog
Thanks Dave, I'll look there as well.
