| | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 39 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 39 | on my 55 ist series with 3 speed on column, shifting for first to second, I have to a straight h pattern shift, otherwise it sometimes locks between gears. is this going to be an easy fix? any suggestions what is causing this problem? if I am driving alone and this happens, it is a problem. you really need one person putting in the clutch while a second person plays with the linkage. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You need to pull the shifting box off the column & rebuild it or exchange for a rebuilt one. Also make sure all the linkage & bushings are snug. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | There are numerous parts which need to be checked for wear. All of the shifter rod ends and the holes in which they fit, the bell crank pivot bolt, the shifter box case (aluminum). I would start by removing the shift box cover and make sure that it is lined up correctly when the transmission levers are in the neutral position. If everything in the box is not lined up, it may be as easy of a fix as adjusting the shift rod length at the shifter box arms. If all of these items don't fix your problem, make sure that your rear engine mounts are like new. Any movement in the engine due to worn mounts will change the geometry of the shifter linkages. Carl
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | "You have to do a straight h pattern"? Don't know what that means but you have to do an H pattern that's for sure. SOoooooo what's the problem? Are you trying to do a X pattern? Does the fact you used lower case h telling us something? Does it mean you are going from 1st to 3rd? (am I slow?) I assume all old column shifts have loose pivot points, bushings and etc. They ain't no speed shifters. Also can you explain "locks" between gears. I was trained to take problems slow and easy and find out exactly what the complaint and manifestations are before moving into tear apart. I'm not tryimg to be a pain in the butt, but slow down here boys. Let's get some freakin info before he spends all his beer money and has a pile of little greasy parts. Gman: If you do a nice easy H shift, is everything OK?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | I think what he means by doing a straight H pattern is that when coming out of 1st going to 2nd he has to sorta go towards reverse then to 2nd.
I had a 63 1/2 ton that did this and it would get stuck. I had to crawl under the tuck and manipulate the shifter arms and get it unstuck. The shifter linkage parts were worn out.
1959 3100 Apache Fleetside
